Strange Gaps in Images with Specific Colors on MX-C311
  • CES_Imaging
    • Nov 2012
    • 65
    I have two MX-C311 machines I'm working on refurbing. I'll be honest, they've been sitting unused in a warehouse for the good portion of a year. When I printed some tests using SIM 64-1, I noticed some absences in areas of specific colors. Black and Yellow on one, Magenta and Yellow on the other. I've swapped developers, drums, transfer belts, cleaned the LSU, none of it seems to fix the gaps. They're consistent across the width of the document and seem to happen only on the edges.
    Here are scanned samples.
    MX-4101N_20140326_125804.pdfMX-4101N_20140326_125826.pdf
    Any Ideas?
    • 23008
    Re: Strange Gaps in Images with Specific Colors on MX-C311
    To me it looks like the developer starter has shifted to one side of the unit. We see this all the time on new Kyocera units that have been stored on end.
    For the Kyocera units we determine which side is lacking developer, then vigorously shake some developer in that direction (the individual developing unit, not the whole machine). Running a stir does not seem to help, even after 4 or 5 tries. It's just a waste of time. If you look at the developing brush, you should be able to detect the lack of fill. =^..^=
    • CES_Imaging
      • Nov 2012
      • 65
      That was my first thought too, but I've swapped developer units completely and there isn't a change at all. The same area is blank, down to the millimeter. The brush looks completely and evenly coated on all 4 colors. I also tried different drums, drum units, I tried a different transfer belt and I wiped off the LSU. Is there a PTC in this machine? I doubt that is the issue but it's something to try.
        • 23008
        It's possible that it's a primary transfer issue. Remove the transfer belt, and check that the individual transfer rollers are snapped into their holders. They are notorious for falling out, even in new units.
        You can test this by emergency stopping the machine and check that the developed image on the particular color drum is good, yet the developed image on the primary belt is incomplete. =^..^=
        • austonrush
          Sharp & HP Tech
          • 234
          It's possible that it's a primary transfer issue. Remove the transfer belt, and check that the individual transfer rollers are snapped into their holders. They are notorious for falling out, even in new units. =^..^=
          I agree, it looks like a transfer problem, try printing a sold page of colour and stop the copier mid print. Are the drums fully coated? If so you have a transfer issue.
          • elamurugu
            • Mar 2014
            • 27
            The colour drum unit seel open and touch the ITB.
            • Akitu
              Legendary Frost Spec Tech
              • Oct 2010
              • 2595
              This can also happen if the primary transfer gear cracks and the belt begins slipping.
              • CES_Imaging
                • Nov 2012
                • 65
                The Transfer Belt rollers are in place and the gears look ok.
                • Akitu
                  • Oct 2010
                  • 2595
                  Have you checked your laser shutter functionality?
