ARM350 with E7-02 error
  • axyun
    • Aug 2007
    • 1323
    Think LSU board might be bad.
    Does whole lasr unit have to be ordered. I tried to get part number off board and saw "N1455FCE1" so I assumed it was CPWBN1455FCE1 but got "invalid part number" at Sharp-Service.
    Any info is very much appreciated. Frank/ActionPhotocopy
  • MHeon71
    • Oct 2008
    • 489
    Re: ARM350 with E7-02 error
    I do not think you can just replace the laser PWB. I do not have that manual for the AR-M350, but the AR-M355 parts manual only gives you the option to purchase the polygon motor or the whole LSU.
    • axyun
      • Aug 2007
      • 1323
      Thanks Mark.
        • 23008
        Ditto that. You can get the polygon mirror motor, but nothing else separately. There's a bulletin somewhere to that effect. It looks as though you'll have to splurge on the assembly. =^..^=
        • axyun
          • Aug 2007
          • 1323
          It could actually be PCU. I was hoping LSu as it was less expensive and when I saw part # on board I was hoping it was available separately. Time for a drink. Have a good weekend. Frank
