Sharp AR M 455 N ADF Registration Problem
  • Doug James
    • Jan 2012
    • 935
    [CQ] Sharp AR M 455 N ADF Registration Problem
    I have the manuals but having trouble understanding how to adjust the ADF registration. (Need to go up about 1/2 an inch). The registration up to the optics is fine. Can anyone tell me how to do this... Thanks so much for any help...
    • 23009
    Re: Sharp AR M 455 N ADF Registration Problem
    It's 53-08-02. =^..^=
    • Doug James
      • Jan 2012
      • 935
      The lead edge timing is OK I am having issues with the side being to far down. I am assuming that it is a mechanical adjustment (Moving the ADF). Do you know the page number in the manual for that. I can't seem to find it. Sure appreciate you !!!
        • 23009
        Sorry, this makes no sense to me. Can you explain in more detail please? Re-positioning the SPF is definitely not the correct approach. You'll create quality and jamming problems.
        If you're talking about SPF side registration, it's 50-12-4 for side1 image, and 50-12-5 for side2 image. See pg 9-61 of your manual. =^..^=
        • Doug James
          • Jan 2012
          • 935
          Thats it, Once again you've saved my butt... That's why I was having trouble. It's an NVM setting... duh... Thanks again !!!
            • 23009
            I'm glad that helped you. =^..^=
