MX-M5111 - Scanned to email image has a reverse image
  • MHeon71
    • Oct 2008
    • 489
    I have a couple copiers at 1 location that are having the same issue of reverse image and one that is fine.
    When scanning to any email, there is a reverse image. Black is white and vice versa. Copies come out fine. This is happening on 2 copiers
    There is 1 machine that sends the scans to emails just fine.
    I have tried device cloning and storage backup from the working machine, same issue. I have flashed the firmware and have the same issue. I do not see an option for reverse image.
    I do not feel that the issue is in the optics or SCN PWB. Maybe MFP PWB?
    Has anyone else seen this?
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MX-M5111 - Scanned to email image has a reverse image
    What is the original image? Have you tried a test chart?
    • MHeon71
      • Oct 2008
      • 489
      Have not tried a test chart. Regular text document that comes out fine on copies and the white portion is black and black is white on scan jobs. It occurs on every scan. Did not think of making a sample.
      • CorbinDallas
        • Mar 2012
        • 56
        As much as it might hurt I suggest you back machine with Sim 56, clone and address backup. Then run the end of lease mode to restore settings to factory. Manually set up SMTP and test scan to email. Can determine if clone or address book etc if stops working right after restoring.
        • draph
          • 132
          This is a question, not an answer. Is it possible to set b/w reverse as the default in the admin settings? I've never checked but I'm wondering if it could be that simple?
            • 23007
            Intriguing ... =^..^=
            • MHeon71
              • Oct 2008
              • 489
              I will check for for reverse copy as a default. I will also reset settings and configure from scratch.
              • MHeon71
                • Oct 2008
                • 489
                Thanks for the help. I have not seen the reverse image as a default option. I did not get to the factory default, but the issue ended up being low compression. Only the destinations with low compressions experienced the issue.
                  • 23007
                  It sounds like a firmware bug that you were just lucky enough to be the first to find. =^..^=
                  • CorbinDallas
                    • Mar 2012
                    • 56
                    Did you clone addresses from another model? That would cause odd settings and problems.
                    • MHeon71
                      • Oct 2008
                      • 489
                      I did, but I do not believe that to be the issue. I think the client may have added destinations with low compression. Not all addresses were faulty.
