AR-M257 Reader CQ problem
  • Jaycat718
    • Oct 2013
    • 70
    Hey guys,
    Hopefully you guys can help me out with this. I have an AR-M257 that keeps repeating lines on the pages. It only happens when using the reader. Internal prints come out with no problem.
    I have run a scanner lamp test, and the lamp looks fine. It moves without any hesitation. I have replaced the Lens unit, but no to no avail. it is 10 years old, and has never had any boards or lamps replaced on it. Only Pm's. It is isn't throwing any codes either.
    No usb port, no network expansion kit. it is only used for copies. Let me know what you guys think.ARM257CQ.pdf
    Thanks Guys!
  • igi
    • 1507
    Re: AR-M257 Reader CQ problem
    hi try replacing the copy lamp harness
    • Jhonjon
      • Sep 2013
      • 208
      Originally posted by Jaycat718
      Hey guys,
      No usb port, no network expansion kit. it is only used for copies. Let me know what you guys think.[ATTACH]25375[/ATTACH]
      Thanks Guys!
      Hi! as you said you've replace Lens, Try the CCD, This kind of lines you attached is not usual if the mirror are dirty or you have a problem in Lamp. Try also to lit the exposure lamp thru program and try to move forward and back the scanner manually and see if the lamp will flicker. try also to clean the reflectors and see if there is some stains in the mirrors. Try to check also the rollers with bearings at the middle attached to the scanner cables.
      Hope this will help...
      • mttech
        • Mar 2014
        • 127
        I had strange lines similar to this on a ARM237 and it was the IMC PWB. Lucky I had 1 to swap out for troubleshooting.
          • 23010
          If you had said that it occurred on all copies and prints I would immediately said "laser". But if internal reports and prints are OK, and you've already replaced the CCD, all that leaves you with is the IMC and a few ribbon cables.
          It would cost you nothing but time to examine the ribbon cables, and clean the contacts with alcohol or contact cleaner. Also check for obvious breaks. =^..^=
          • Jaycat718
            • Oct 2013
            • 70
            So today i revisited the machine. I reseated all of the ribbon cables on the pwb's. i checked all of the ribbon cables, and they look flawless. i wiped the contacts with alcohol. I even reseated the MCU. No luck. i will see if we have another 257 in the warehouse to swap out the IMC Pwb. I will let you guys know the result.
            • CorbinDallas
              • Mar 2012
              • 56
              Was your sample a scan of a blank sheet? You could narrow it down further by reducing the image to 50% to see if marks stay the same or reduce.
              • Jaycat718
                • Oct 2013
                • 70
                Yes it was a blank page.
                • 914fan
                  • Jun 2014
                  • 7
                  looks like bad memory.
