admin password
  • dibyendu
    • Jan 2011
    • 53
    [CQ] admin password
    One of my customer change and forget admin password in MX-M202D. can any one tell me how I reset that password. Machine is equipped with MX-NB12.
  • bilyahn
    • Dec 2006
    • 1470
    Re: admin password
    Sim 22-7 will get you the current passcode for the machine if that is what you are looking for.
    Good luck.
    Bil
    • dibyendu
      • Jan 2011
      • 53
      In this new models dose not support SIM 22-7. Any other suggestions?
      • faxman28
        • 435
        Re: admin password
        if the password is for the nb12, just reset the nb12
        also 22-7 shows main body code.
        • igi
          • 1507
          Re: admin password
          hi yes you can reset with nb-12
          you need to download a file to you USB/memory stick
          unzip. do sim 49 and run the file
          • dibyendu
            • Jan 2011
            • 53
            Ok. Tomorrow I will try NB12 reset with usb stick. I have that firmware in my laptop.
            • dibyendu
              • Jan 2011
              • 53
              After upgrading MX-NB12 it's admin password not reset. Problem still not solved. Any suggestions welcome..
              • ZOOTECH
                Senior member of CRS
                • 3375
                Re: admin password
                There is a small push button switch on the NB print controllers - hold that button while powering up, it will give a configuration page and reset password to default.
                • faxman28
                  • 435
                  Re: admin password
                  nb12 is internal pwb , not the hump, unless boad has a reset button on it. I hope it's not like the 2610 and newer were you have to send board to Sharp to reprogram
                  • ZOOTECH
                    • 3375
                    Re: admin password
                    That's what I get for not verifying what I thought was correct - there goes my credibility.
                    • CorbinDallas
                      • Mar 2012
                      • 56
                      Re: admin password
                      The MX-NB12 password itself cannot be reset if lost. The entire MX-NB12 CAN be set back to factory default by uploading the factory reset file using sim 49-2 and a jump drive. In the past you had to contact your rep or the hotline in order to request a copy of the file. It is not published.
                      • dibyendu
                        • Jan 2011
                        • 53
                        Thanks friends for your valuable feedbacks.. I have send mail to my HO for sending That firmware..
