Sharp MX2314N Hanging Screen
  • Dazza
    • Aug 2012
    • 15
    [Dead] Sharp MX2314N Hanging Screen
    Hi
    Has anyone had any issues with a Sharp MX2314N in which the screen just hangs on the Sharp Logo Screen my colleague is having this issue the machine doesn't have a Hard Drive just an SD Card he thought the issue may of been with the MFP board of which he changed and still gets the same problem.
    Any Ideas or any suggestions Welcome
    Thanks in Advance
  • glewisme
    • Nov 2009
    • 240
    Re: Sharp MX2314N Hanging Screen
    I would try the SD card itself.
    • Dazza
      • Aug 2012
      • 15
      I've seen a few posts of similar issues where people have changed the SD Card and it not work thanks for your input tho much appreciated
      • faxman28
        • 435
        check your service manual, if the mx2314 is similar to US model mx2615, on mfp board below heatsink there is an led if it is on and red that is supposed to indicate problem with sd card, also in troubleshooting section of manual it description of boot sequence leds on mfp board it may help. Also make sure write lock switch on SD card didn't get turned on . This will cause machine not to boot or throw error.
        • Dazza
          • Aug 2012
          • 15
          Thanks a lot faxman this May help my colleague I shall pass this on once again really appreciate the feedback
