AR337 error H4-01
  • Walter Chavez
    • Oct 2007
    • 14
    AR337 error H4-01
    I have a AR337 with the H4-01 error, I got new fuser on the unit with the same result. What else can I check or do?, ASAP please.
    Walter
  • ZOOTECH
    Senior member of CRS
    • 3375
    If new fuser didn't take care of it, my best guess would be the AC power supply. The triacs for heater lamps are located there. Of course, the harness from AC ps to the fuser connector or the connector itself could have trouble....or, the PCU pwb isn't giving the signal to turn on HL2. Good Luck
      • 22995
      The real test is to clear the code, then while powering up meter on the AC 110VAC range:
      DC Power Supply CN203-2 to positive
      DC Power Supply CN201-1 to negative (HL1)
      then DCPower SupplyCN201-3 to negative (HL2)
      If you're getting no voltage then it's the power supply.
      If you're getting your voltages (~100v), but still no lamps lit it's the harnass or something in the lamp circuit.
      If you're getting your voltages, lamps light, but error out after ~30 seconds it could be the thermistors, the PCU, harnass to thermistors, or the thermistors may not be contacting the roller.
      • mtech
        • Mar 2007
        • 307
        Check your wall voltage. Also if you replaced the whole fuser unit you are only left with PCU and power supply. If the lamps come on at all it is most likley the PCU because the power supply is functioning.
        • deep
          • Jun 2008
          • 208
          Do not forget to reset the error code with sim14 after replacing the fuser.
          Kenny
          • Walter Chavez
            • Oct 2007
            • 14
            I change the Fuser and reset the error, had to do it twice to reset.
            Thanks you all
            • joetennisjoe
              • Aug 2008
              • 16
              I have the same code on the same copier h4-01, had changed the upper fixing roller, both thermistors had been replaced 2 months ago, I think it might be the thermoswitch, the lamps do not come on, after resetting code.
                • 22995
                See above:
                • Toner Boy
                  • Aug 2007
                  • 357
                  IC22
                  Believe it or not...we tried all these things and failed (including replacement of the PCU board and flashrom). Noticed a tech tip on SharpNet regarding the IC22 EPROM chip on the ICU board.
                  Replaced it (VHiAT28C64B-1 ?) and the problem never returned. I think it was also throwing some U-? codes alternately every time the H4-01 would appear.
