ARM207 Colour Scanning
  • Andyrsv
    • Jun 2008
    • 59
    I have just installed an overhauled ARM207 in a customers today but can't get it to scan in colour at 150dpi. B/W works fine but colour scans cause it to just sit there with "reading" on the display and has to be turned off to reset. I think it may need extra memory on the ARNB3 but I had to leave before I could check. Checking the specs on the Sharp UK web site , it looks that the memory is only needed to scan at 600dpi but it should scan 150dpi colour as standard. Anyone else had this problem?
    • 22997
    That's an excellent place to start. The memory upgrade for the AR-EB9 is 256MB (Sharp part# SHP32X64S133C3-B).
    • Andyrsv
      • Jun 2008
      • 59
      One of my colleagues fitted the memory upgrade for the AR-EB9 but then the machine had a blank screen. I will be trying ARNB3 memory Monday. If that does not work Im not sure what else to try.
      • swagreis
        • Jun 2008
        • 92
        i dont think that it is a memory problem
        I made the color scan in ARM205 at this 300 dpi without adding any memory.
        The scan u did from the machine or from the computer .
        Try the method u did not use.
        If u use the computer to scan try to change USB port or install another prpgram to scan.
        • Andyrsv
          • Jun 2008
          • 59
          The scanning was sent from the machine to a windows 2003 server which I had set up with Scannertool from Sharpdesk. The fact that it sends B/W scans ok would suggest that the PC side is set up ok but when scanning colour it just sits there displaying "reading" as if it can't manage that much data.
          • Andyrsv
            • Jun 2008
            • 59
            Turned out to be a faulty EB9.
