mX-4501 scanning
  • teklife256
    • Sep 2012
    • 164
    mX-4501 scanning
    Just recently a customer scan to email stopped working. The mfp is a mx-4501 using the following SMTP settings:
    smtp.gmail.com
    port 587
    smtp authentication is enabled using a gmail account
    I realize that this machine does not support SSL and am curious if that has anything to do with the recent failure to scan. Any other ideas?
    The connection test within the MX web page is successful however from the mfp I receive the typical scanning errors at the display.
    What gives??
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: mX-4501 scanning
    smtp.gmail.com
    port 587
    What gives??
    If your device or application does not support SSL - connect to aspmx.l.google.com on port 25.
    From this page: https://support.google.com/a/answer/176600?hl=en
    I haven't tried it, so, I don't know if this will work or not.
    • teklife256
      • Sep 2012
      • 164
      Just now read the details in the link. Entry in Spf record? Recipients must be gmail? There must be another workaround with this non-SSL machine. Right??
      • ZOOTECH
        • 3375
        Yeah, I didn't understand that either - maybe one of the experts will post. There probably is a fix other that an upgrade.
        • teklife256
          • Sep 2012
          • 164
          Maybe there is a custom frimwar out there. Yikes!
          • ruben
            The New Guy
            • Oct 2012
            • 1203
            Use GMX instead.
            • teklife256
              • Sep 2012
              • 164
              Originally posted by ruben
              Use GMX instead.
              Not familiar with that. Well have to Google. Insight?
                • 23008
                Most endusers that scan to Gmail never actually log in to their account, so Gmail just cuts them off due to inactivity. All they have to do is log on once in a while, and clear out the spam. =^..^=
                • faxman28
                  • 435
                  The Sender Policy Framework (SPF) is an open standard specifying a technical method to prevent sender address forgery. More precisely, the current version of SPF — called SPFv1 or SPF Classic — protects the envelope sender address, which is used for the delivery of messages. See the box on the right for a quick explanation of the different types of sender addresses in e-mails.
                  (There are other solutions that protect the header sender address or that do not care at all about who sent the message, only who originally wrote it.)
                  Even more precisely, SPFv1 allows the owner of a domain to specify their mail sending policy, e.g. which mail servers they use to send mail from their domain. The technology requires two sides to play together: (1) the domain owner publishes this information in an SPF record in the domain's DNS zone, and when someone else's mail server receives a message claiming to come from that domain, then (2) the receiving server can check whether the message complies with the domain's stated policy. If, e.g., the message comes from an unknown server, it can be considered a fake.
                  Once you are confident about the authenticity of the sender address, you can finally "take it for real" and attach reputation to it. While IP-address-based reputation systems like Spamhaus or SpamCop have prevailed so far, reputation will increasingly be based on domains and even individual e-mail addresses in the future, too. Furthermore, additional kinds of policies are planned for a future version of SPF, such as asserting that all of a domain's outgoing mail is S/MIME or PGP signed.
                  looks like google is adding extra security to their email If the users are not sending to a gmail or google apps account without ssl it now will not go through. Unless you use google smtp relay service which I think is a pay service. Check the connectivity forums as there as been threads about gmail not working recently from mfps. Try Blackcats' suggestion of going into the gmail account for the mfp and deleting messages and the such. Depending on when google added the "SPF" to the emails the mail servers down the line can't verify the address/domain of were the email is coming from.
                  On the mfp web page when you do the connection test, all it does is verify that the address of the mail server is a mail server.
                  • lky1978
                    • Mar 2009
                    • 483
                    this model support ssl authentication
                    • Akitu
                      Legendary Frost Spec Tech
                      • Oct 2010
                      • 2595
                      As of the latest E22 firmware release according to Canadian support site, SSL is not supported. I happened to have gotten some custom firmware from Sharp for this and have been testing it with no problems as of late. Initial concern was to watch out for a non-existant fan error on machines older than '08.
                      • Ceechtay
                        • Sep 2011
                        • 158
                        You can use Stunnel (www.stunnel.org) to handle SSL communication with Gmail. This would require a computer to be on whenever they want to send an email scan. It is pretty easy to set up.
                        Basically, just install Stunnel on a PC, open up the port in the PC's firewall, and then change the copier's settings to point to that PC instead of Gmail's SMTP server.
                        After installing Stunnel, you can configure it's "stunnel.conf" file (Start->All Programs->stunnel->Edit stunnel.conf). Basically, you only need to un-comment(remove the ;) this section (or add it):
                        [gmail-smtp]
                        client = yes
                        accept = 25
                        connect = smtp.gmail.com:465
                        The "accept" attribute is the port that Stunnel listens on and can be whatever you want. You just need to make sure that the Sharp copier uses that same port. That is also the port that you need to open up in the PC's firewall.
                        So on the copier side, your settings would be:
                        SMTP Server: 192.168.1.x <- either IP address or hostname of the PC with stunnel on it
                        Port: 25 <- MUST match the port number in the "accept" property above
                        Reply email: whatever you want
                        Authentication: checked
                        Username: valid Gmail account (example@gmail.com)
                        Password: Gmail account's password
                        If you have problems, just make sure that Stunnel service is installed and running and try disabling the PC's firewall to make sure that is not causing the issue.
                        Lastly, you would want to make sure that stunnel starts automatically when the computer boots.
