Sharp MX M363 Sharp OSA MX-AMX 1,2 & 3
  • Doug James
    • Jan 2012
    • 935
    [Misc] Sharp MX M363 Sharp OSA MX-AMX 1,2 & 3
    I have a Sharp MX M363 that I am selling to a customer. This customer is a trial Lawyer and wants the scan numbering system that works through
    Sharpdesk (Sometimes referred to as "Bates Numbering"). The Software is listed as an option as 3 different part numbers. MX-AMX (1 thru 3) Will I
    need to get all of these to make the numbering system work and also purchase Sharpdesk. Any help is so much appreciated Thanks !!!
  • Toner Boy
    • Aug 2007
    • 366
    Re: Sharp MX M363 Sharp OSA MX-AMX 1,2 & 3
    I believe you will need a third party application like Drivve or similar to do the Bates stamping they require. It will require the MX-AMX2 installed (which should be standard on that model 'ACM' Application Communication Module) to function with the software. You may be able to get a trial version of the software from various companies, check the web. Here is a link I found, you should try and contact them to verify which module is required.
    Discover managed IT services, print solutions, and security tools to support modern business operations with Visual Edge IT.
    Go to Drivve and search 'Bates numbering'
