Sharp AR153E Error Blinking Message H3
  • blacktriangle
    Guys and Gals,
    How can i rectify the error in the AR153E Copier with Error blinking message H3.
  • NCArt
    Mountain Tech
    • May 2008
    • 81
    The H3 message is for an abnormally high fusing temperature. The thermistor has probably built up with toner and is giving bad readings. Try resetting the code first, then clean the thermistor.
    • mtech
      • Mar 2007
      • 307
      How many copies on the fuser? It may be time to replace it. Check thermistors and lamp and thermostat.
      • blacktriangle
        bro, where this part located? do i have to disassemble the plastic or i can hardly reach by removing toner?
          • 23010
          Now would be a great time to open the phone book and dial up your local copier professional. If you don't know what the fuser looks like, you're going to need more help than we can provide here.
          • JustManuals
            • Jan 2006
            • 9838
            But if he had the manual even a monkey could prolly figure it out.
            Paul@justmanuals.com
            • NCArt
              Mountain Tech
              • May 2008
              • 81
              If you have to ask that, might I suggest you find a qualifed technician.
              • repair.code
                • Jun 2008
                • 5
                Chang Heater Lamp
                Chang Heater Lamp
                Good Luck
                • johnbla
                  • Apr 2005
                  • 94
                  Originally posted by repair.code
                  Chang Heater Lamp
                  Good Luck
                  you a Salesman or a Tech...??
                  If it's getting too hot ~ H3-00, then the Heater Lamp inside the Fuser is working fine....but the Termistors, which control the Temp/Lamp are not....
                  Think before you post.
                  regards
                  John
                  sigpic
                  " The Game never ends..When your whole World depends..On the Turn of a Friendly Card..."
