The H3 message is for an abnormally high fusing temperature. The thermistor has probably built up with toner and is giving bad readings. Try resetting the code first, then clean the thermistor.
bro, where this part located? do i have to disassemble the plastic or i can hardly reach by removing toner?
Now would be a great time to open the phone book and dial up your local copier professional. If you don't know what the fuser looks like, you're going to need more help than we can provide here.
