Sharp SF2040 error code question
  • bubbabear
    • Jul 2008
    • 23
    It's been awhile since I have worked on one of these and I don't have the service manual to it or the crop codes as well.
    Does anyone know what an error code U5-00 means?
    Bubba Bear is off to the maul.
  • johnbla
    • Apr 2005
    • 94
    Document feeder Comms trouble.. check the cable connections, turn the power off first................
    regards
    John
    sigpic
    " The Game never ends..When your whole World depends..On the Turn of a Friendly Card..."
      • 23006
      As I see it you've got four things to look at:
      Check to see that your getting the 24 vdc to the SPF controller. These machines are old enough that there is still color coding to the harnass. If yes, you can rule out the pigtail and power supply.
      If no, then check the 24 vdc at the power supply. If the power supply is good then pinout the pigtail to the SPF for broken leads to the 24vdc lines(wiggle test).
      If there is 24 vdc at the SPF controller, then it's either the SPF controller, the PCU, or the pigtail to the controller.
      I usually use the cost rule: I do the free things first, then the cheap things, then the expensive things. So you can do the voltage checks & pinouts for free (labor only), then the pigtail fairly cheaply (if it's still available, or possibly repair a broken lead), then the SPF controller & PCU last.
      Oh, you do have one more option. Pitch the SPF in the trash and stick a flat top on it. Let us know how it goes.
      • bubbabear
        • Jul 2008
        • 23
        It was easy
        The ADF was unplugged. Powered it back up and it worked.
        He claims there is accounting enabled on that machine. How do you turn that feature off.
          • 23006
          If we're talking about ID codes, I don't remember anything about them. If the ID codes are on and you made copies, you must have at least 1 valid ID#, correct?
