GMAIL Configuration in MX-2310U
  • dibyendu2008
    • Dec 2011
    • 27
    [Misc] GMAIL Configuration in MX-2310U
    daer all,
    one of my customer requested me to configure his machine scan to mail function through GMail.
    can any one give me the GMAIL CONFIGURATION setting and steps to be followed.
    thanks in advance.
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: GMAIL Configuration in MX-2310U
    In the CTN advanced search bar above type in "gmail" <enter>
    You will be able to read many threads on the subject...
    HTH
    • Akitu
      Legendary Frost Spec Tech
      • Oct 2010
      • 2595
      Here's the "for dummies" version.
      SMTP server smtp.gmail.com
      Port 587
      Get an email address and password, then put them in, dummy.
      • foudl
        • Mar 2010
        • 138
        Here for you test2.pdf
        • Toner Boy
          • Aug 2007
          • 366
          and...be sure your DNS settings are correct
          • mojorolla
            The Wolf
            • 2627
            Originally posted by foudl
            Here for you [ATTACH]26636[/ATTACH]
            Nice bulletin Sharp....LMAO.
            Command prompt AND not sure of which port to use...priceless!!!
            • Toner Boy
              • Aug 2007
              • 366
              Well, Gmail used to always be 465/SSL but now I had to use 587, AT&T used to be 587 but then I had to use 25 WITH SSL; geez, gotta make more friggin work for us all the time, they never notify anyone when they decide to change things (and that means you too Comcast !)
              Then there was the new Comcast digital fax line that would hang up on an FXX1 fax box until we switched the 4-conductor phone line to a 2 conductor...love my job
              • mojorolla
                The Wolf
                • 2627
                I always use the 2 wire cords; ALWAYS. Also have a dozen backups in the trunk just in case.
                If it is hard wired behind a wall, I tell them no guarantees for that fax line.
                That being said, 2 or 4 wires only get you so far on a digital or VOIP fax line.
                And now for something completely off topic....
                Toner Boy, ever see Lemmy: The Movie...?
                Your avatar made me think of it. It has been running on Showtime as of late.
                • NeoMatrix
                  Senior Tech.
                  • 3513
                  Google gmail sometimes has some hickups with MS Outlook and setting up for gmail accounts.
                  pop or imap. Google gmail combines both into one.
                  incoming server :
                  imap.gmail.com
                  SSL
                  port 993
                  outgoing server :
                  smtp.gmail.com
                  SSL/TTL
                  port
                  465
                  in a Dos window
                  ping imap.gmail.com -a for address resolve IP
                  ping smtp.gmail.com. -a for address resolve IP
