arm355n
  • foudl
    • Mar 2010
    • 138
    [CQ] arm355n
    test.pdf
    I have bad cq when using duplex, the lines on b side seems thicker, which adjustment should i use to get the image clear, the cis is clean.
  • ntbann
    • Jan 2012
    • 627
    Re: arm355n
    What have you done so far? If this 22-6 print out is from this machine you need an exit unit also.
    • ZOOTECH
      Senior member of CRS
      • 3375
      Re: arm355n
      I wouldn't put too much money in this machine with over a million on the meter.
      • foudl
        • Mar 2010
        • 138
        Re: arm355n
        Yes the 22-6 is from this machine. It is scan from the cis (duplex), no prob with the printer it seems to come from the cis, What do you mean when you say that i need an exit unit also .
        Thanks.
        • ZOOTECH
          • 3375
          Re: arm355n
          Thanks.
          I think they were referring to the jam codes.
          • foudl
            • Mar 2010
            • 138
            Re: arm355n
            Yes i know that it is old ,but i just want to know if someone saw it on one of his machine ,does anyone ever changed a cis on these machines ,the jam map does represent the jams over a 3 months basis ,so it's not a real issue here.
            • ZOOTECH
              • 3375
              Re: arm355n
              Yes, we have had to replace the CIS on this family and the Dragon series.
              • lky1978
                • Mar 2009
                • 483
                Re: arm355n
                [ATTACH]26635[/ATTACH]
                i have done more 10 units in field, just replace the left feeder hinge MHNG-0209FCZ1 .
                The feeder hinge bent and cause the CIS unit not touch completely with the White datum glass unit CGLSP0102DS51
                • Akitu
                  Legendary Frost Spec Tech
                  • Oct 2010
                  • 2595
                  Re: arm355n
                  Million copies on the unit? If the main drive pack hasn't already been replaced you should do it as a precautionary measure. Once the drive pack hits those numbers it starts to slip and you get lots of extra jamming out of tray 1.
                  • foudl
                    • Mar 2010
                    • 138
                    Re: arm355n
                    Yes it was done at 700k,so i should be good for a while
