Odd white rectangle in every copy
  • mikeg1265
    • May 2014
    • 10
    [Misc] Odd white rectangle in every copy
    Good day,
    I came across a strange issue on a Sharp ARM-277. Whether the customer prints from ADF, Glass, or PC; the image or document produced is missing toner about a half inch by 3 inches in the upper right hand corner about an inch and a half down the right side of every page. I've changed the fuser, PCU parts, developer. I've cleaned the optics, mirrors, latest firmware, I've cleaned the glass, checked cables, I'm at a loss. I've never seen this before on any copier. If anyone has any ideas, I'd be grateful.
    Regards,
    Mike G.
    Valley Imaging Solutions
    Sierra Vista, AZ
    • 23008
    Re: Odd white rectangle in every copy
    How do internal reports look? Prints? Scans? =^..^=
    • mikeg1265
      • May 2014
      • 10
      Even reports, scans, images, forms, copies, they all have a white rectangle from right to left about 3 inches long x 1/2 inch
        • 23008
        1) I think I'd re-seat the ribbon cable to the laser
        2) Replace ribbon cable
        3) Replace laser
        • ZOOTECH
          Senior member of CRS
          • 3375
          Sounds like a label is stuck somewhere (usually on the drum or fuser roller), but you changed those parts; laser as BC says or IMC pwb.
            • 23008
            If it was a label, Zootech, it should appear twice on LTR or three times on LTR-R, repeating at 96mm intervals, and it would not stay at the leading edge. It would walk. =^..^=
            • ZOOTECH
              • 3375
              Thanks for waking me up - it's been one of those days when everyone has been on my arse about setups, shop repairs, and walk-ins.
              • NeoMatrix
                Senior Tech.
                • 3513
                Check the scanner rail is lubed and it doesn't jump upward/vertical due to gunk on the rail.
                I have seen similar in dusty workshop machines.
                • ZOOTECH
                  • 3375
                  Check the scanner rail is lubed and it does jump upward/vertical from gunk on the rail.
                  From the above posts, it's not a scanner/optics problem; so, I'll go back to the IMC pwb as an option.
                  • brokey
                    • Oct 2011
                    • 22
                    Check the memory on the IMC PWB
                    • mikeg1265
                      • May 2014
                      • 10
                      Thanks everyone, I'm gonna check it out today and let you know.
                      • Akitu
                        Legendary Frost Spec Tech
                        • Oct 2010
                        • 2595
                        Check your mag roller in dev unit too. I've seen these things do voodoo.
                        • tr210907
                          • Jul 2011
                          • 40
                          Has any one replaced the paper feed roller in tray 1? If so I would check those 3 plastic screws to ensure all are tight. You can visually look and make sure that cover is flush all the way across. If that cover is raised it will cause trouble as you have indicated ..
                          • MdangerP
                            • Sep 2014
                            • 45
                            I have seen this happen a couple times on similar models. One was mag roller one was transfer roller. If its happening on internal prints, such as 22-6 report, then it more than likely is not the laser.
