FN20 ISSUE
  • copyguy1
    • Jul 2011
    • 142
    FN20 ISSUE
    Have a FN-20 fin. that when saddle stitching the papers dont line up the top sheet is off . We tried the same paer on a FN-24 and it works great. It also works on a MXM623 saddle stitch finisher. This a new unit. The paper is 11x17 28lb super smooth. Any ideas of what to try? Thanks
  • ktucker
    • Apr 2012
    • 23
    Re: FN20 ISSUE
    did you find a fix?
    I have one doing the same thing
    the sharp hotline told me to adjust saddle rollers
    I cant find the adjustment
    • copyguy1
      • Jul 2011
      • 142
      Re: FN20 ISSUE
      Everybody I talked to at sharp thinks it is strictly a paper issue. The customer is changeing to a different paper.
      • tee
        • Aug 2014
        • 79
        Re: FN20 ISSUE
        Did you ever fix this?
        I have one doing the same thing only on 11x17.
        • ktucker
          • Apr 2012
          • 23
          Re: FN20 ISSUE
          I modifiyed the crescent rollers
          in the lower exit part of the finisher
          by removing the rubber tire and adding a flapper ,
          no problems yet
          it seems to be a paper issue
          I will post pics and part #s
          • ktucker
            • Apr 2012
            • 23
            Re: FN20 ISSUE
            the roller is in the bottom of the finisher at the saddle exit tray
            you can remove the tape that covers the hole and open exit door with a pair of pliers
            I removed the rubber tire
            cut a slot in the hub and added the
            flapper, I did trim the flapper down just enough to touch the paper
            the paper that we are running it 28lb hammermill
            as far as I can tell the rollers never touch
            and I think it is a static issue
            with the paper
            this fixed the issue
            part # for the flapper is 0cw4141p320// paddle
              • 23009
              Re: FN20 ISSUE
              Kudos on your MacGuyver. =^..^=
                • 23009
                Re: FN20 ISSUE
                It appears that there is an official bulletin on this topic:
                Enjoy!
                • ntbann
                  • Jan 2012
                  • 628
                  Re: FN20 ISSUE
                  Those adj. didn't help us. We ended up making new rollers as described above. Just went about it differently.
                  • CoreyAbels
                    • Dec 2014
                    • 92
                    Re: FN20 ISSUE
                    Enjoy!
                    Out of curiosity, where did this bulletin originate? First time I'm seeing this.
