AR-M257 Lines on outgoing faxes??
  • Cookr
    • Dec 2011
    • 184
    [Misc] AR-M257 Lines on outgoing faxes??
    Have a customer that is getting lines only on their outgoing faxes, received faxes clean, copies clean, prints clean. I sent a fax to my office and it had lines going across the page I also sent one from just the glass and it still had lines but not as bad. I checked and cleaned the ADF, the slip glass, the glass itself everything seems to check out except for when I send the fax. Any ides a out there? thanks.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: AR-M257 Lines on outgoing faxes??
    Try adjusting TC 46-12.
      • 22996
      Did you clean the rest of the optics, mirrors, lens, reflectors, and white plates?
      • walterman
        • 196
        Clean your optics... Copier/fax class 101, if the problem persists then make your exposure adjustments.
        • oldrn
          • 166
          It's Monday but as already been said, clean the rest of the optics, test with manual dark exposure, adjust exposure in simulation if needed. Auto exposure may be hiding a problem that shows with exposure setting (46-12) for fax.
