black copies
  • raider
    Manager
    • Jun 2014
    • 19
    black copies
    hi
    we have an mxm200d with black copies.
    self generated prints are fine in 64 but copies are black.
    with it only happening with an optical scan we thought it may be the ccd unit, it was swapped and unfortunatley has not fixed the black copy fault.
    has anybody got any ideas please ?
    regrds
    Been there, done that, learnt nowt.
    • 23009
    Re: black copies
    That really only leaves image processing ... more specifically the MCU or the IMC2. You seem to have your bases covered. =^..^=
    • Corder
      • Nov 2014
      • 105
      Re: black copies
      Have you checked if the lamp is operational while scanner carriage is moving?
      • ZOOTECH
        Senior member of CRS
        • 3375
        Re: black copies
        Originally posted by raider
        hi
        regrds
        Sorry for asking, but does the copy lamp light up?
        I'm getting older and slower.
        • raider
          Manager
          • Jun 2014
          • 19
          Re: black copies
          Gents
          first off, apologies for the delay in responding.
          the fault turned out to be the mcu pwb, just swapped the nvram around and switched on......
          thankyou for your replies chaps.
          regards
          raider.
            • 23009
            Re: black copies
            Congratulations! And thanks for posting back your solution. =^..^=
