Sharp MX-FR14U
  • lenovos
    • Oct 2012
    • 140
    Sharp MX-FR14U
    Hi I just purchased an off lease Sharp MX-363N with a data security kit. I tried to update firm ware an I get a firmware does not match message. I checked firmware twice.
    Also checked dip switches on MFP power board. juniper 0303jci0
    Thanks in advance
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: Sharp MX-FR14U
    Thanks in advance
    You need to download the DSK firmware, not the machine's firmware.
    Jupiter3_DSK_Conbi_0303jci0_B.sfu
    • lenovos
      • Oct 2012
      • 140
      Re: Sharp MX-FR14U
      That is what I did.
      • lenovos
        • Oct 2012
        • 140
        Re: Sharp MX-FR14U
        That is what I tried, but the machine does not like it. Are their any soft switches that would block it?
        • ZOOTECH
          • 3375
          Re: Sharp MX-FR14U
          Not that I'm aware of; what method are you using for the upgrade?
          • lenovos
            • Oct 2012
            • 140
            Re: Sharp MX-FR14U
            49-1 with a flash drive. I tried both USB ports. the description of the security kit says common crit, does that mean any thing?
            • lenovos
              • Oct 2012
              • 140
              Re: Sharp MX-FR14U
              MX-FR14.pdf Here is description of it
              • tmaged
                Owner/Service Manager
                • Oct 2008
                • 1866
                Re: Sharp MX-FR14U
                You have an MX-FR14 not an MX-FR14U. Common Criteria DSK's are certified & cannot be updated. If you change it, it's no longer certified.
                Hope that helps !
                -Tony
                www.dtios.com
                Become a fan on Facebook
                • lenovos
                  • Oct 2012
                  • 140
                  Re: Sharp MX-FR14U
                  Thank you, I did not know that their was another version. I wish that their was a way to delete those programs. I appreciate all of your responses.
                  • Akitu
                    Legendary Frost Spec Tech
                    • Oct 2010
                    • 2595
                    Re: Sharp MX-FR14U
                    If you can get a regular PRG and Boot ROM set, your data security kit will be gone.
                    • Paulm
                      • 69
                      Re: Sharp MX-FR14U
                      Make sure you don't have the MX-fr23u. Let just say from a certain past experience it shows up as a 14u in the 22-10. See TT TT-20215.
                      • lenovos
                        • Oct 2012
                        • 140
                        Re: Sharp MX-FR14U
                        Are you sure that it is just those two chips? I have removed it from some older machines but I figured that their was more to it on newer equipment.
                        I wonder if I could use MX- 2600 chips flashing them manually? I have a parts machine.
                        Thanks to all again
                        • Paulm
                          • 69
                          Re: Sharp MX-FR14U
                          It will show error code if you install original ROMs. I had to reset Passwords this way on three units and it does show error.
                          • lenovos
                            • Oct 2012
                            • 140
                            Re: Sharp MX-FR14U
                            Nope their is no U
                            • lenovos
                              • Oct 2012
                              • 140
                              Re: Sharp MX-FR14U
                              if you reflashed the machine would the error go away?
