I don't know if this will help you, but this is what Precision shows on their website.
PAPER FEED - Paper Pickup Roller (New Style - Green Tire) - "C" Shaped Tire Only - Machine uses 2 Per Tray - For use in Machines that have been changed to the new style shaft (P/N CSFTZ0066RS71) with the quick replacement snap on/off hubs.
Now which is it? A Panther (AR-207) or a Pegasus (AR-M207)?
The first time you replace the tires with the new style shaft you have to order the whole shaft assy. You didn't mention which tray this was for:
Panther CSFTZ0066RS71 PF Shaft Assy, Top Tray AR-205 CROLP0039QS01 PF Shaft Assy, Top Tray all others (including AR-207). CROLP0043QS01 PF Shaft Assy, Tray#2 all models
