mx 2300n question. b&w print when color is empty
  • danielcooke
    • Jun 2013
    • 22
    Just wondering how you can get a machine to print in black and white when say the yellow toner is empty? can this be done on the 2300n? and how?
  • lky1978
    • Mar 2009
    • 483
    Re: mx 2300n question. b&w print when color is empty
    printer properties
    just tick black & white
    • danielcooke
      • Jun 2013
      • 22
      I am logged in via the web... and carnt seem to find it
      • bilyahn
        • Dec 2006
        • 1470
        He means in the print driver printer properties I believe. However if the toner is empty I do not think you can print or copy anything. I'm pretty sure you must replace the toner to get it operational again.
        Good luck.
        Bil
        PS Would really be interested if you did find a work around for this. We default all of our color machines to B/W in the print driver settings and they all stop printing when out of any toner.
          • 23006
          Install a cartridge of toner of the color that is empty. It works every time. =^..^=
          • padedwalls
            • Dec 2014
            • 40
            Sharp disallows print for many reasons.. PM prompts, toner out, etc..
            There is a setting (can't exactly recall if in SIMS.. service mode) that can be changed to allow printing..
            • padedwalls
              • Dec 2014
              • 40
              • padedwalls
                • Dec 2014
                • 40
                http://www.copytechnet.com/forums/sh...de-copier.html
                • padedwalls
                  • Dec 2014
                  • 40
                  This talks of the appropriate SIM setting to make
                  • colgrimes
                    • May 2012
                    • 64
                    As far as I know when it's out of one color the entire machine stops. If there is a way to work around this I would love to know. We have a couple of "toner emergencies" a week that we could avoid.
                    I've got several how-tos for all kinds of things Sharp on our company website, one of them is defaulting to TRUE B&W, not process black. www.equipmybiz.com
                    -Copier Collin
                    CopierCollin.com
                    Hybrid Honest Sales/IT
                    • Ben Around
                      • Apr 2012
                      • 151
                      -Copier Collin
                      I looked for a enable/disable print setting but couldn't find one. According to the users manual they will continue to print B/W if a color toner is out. Personally I've never noticed one way or the other.
                      Copied and pasted from MX 2300N Users GuideIf any one of the toner colours runs out (including black toner), colour copying will not be possible. If Y, M, or C toner runs
                      out but Bk toner remains, black and white copying will still be possible.
                      • ben@km
                        • Sep 2014
                        • 34
                        Go to Admin mode, under device control there is "disabling of colour mode". This allow the copier to work B\W when you have an error code related to colour. Not sure if this work with 'out of toner" issue too. To reactivate colour mode when issue is solve you need to do a sim14.
                        If this work and you dont want to go on site to do the sim 14 you can instruct your customer to do the "limited test command" by using 9,*,8,#,7, . It look exactly like the regular sim but you can only access a few like the reset one 13 to 17.
