Sharp AR M455
  • mlbcopiers
    • Oct 2007
    • 34
    Sharp AR M455
    I have a customer with a Sharp AR M455 that has the Security package on it. I don't think it showed this when I set it up. The accept the last page scanned screen comes on when copying from the glass. So you have to accept this screen every time you want to print. Two steps, they don't like it. Can this be removed. Not sure when it became active and cant seem to get rid of it.
    Any help will be greatly appreciated.
    Thanks,
  • colgrimes
    • May 2012
    • 64
    Re: Sharp AR M455
    This normally only pops up when 2-sided copying is selected. Make sure the machine isn't defaulted to make 2-sided copies.
    If you lift the lid, place paper, close the lid and hit start it should make the copy with no further button presses. The data security kit has nothing to do with that.
    Hope this helps.
    -Copier Collin
    CopierCollin.com
    Hybrid Honest Sales/IT
    • lky1978
      • Mar 2009
      • 483
      Re: Sharp AR M455
      Hope this helps.
      -Copier Collin
      change the message time from 6sec(default) to 1sec
      • colgrimes
        • May 2012
        • 64
        Re: Sharp AR M455
        There's that too...if that's what you're referring to.
        I thought you were talking about the "Read End" button when copying from the glass that pops up BEFORE you hit the start button.
        -Copier Collin
        CopierCollin.com
        • bilyahn
          • Dec 2006
          • 1470
          Re: Sharp AR M455
          Go into system setting, key operations, copy setting, initial default setting, output and select auto. That should get rid of your message when you copy from the glass on single sided.
          Good luck
          Bil
          PS may not be the exact path directions but it will get you in the ballpark.
          • mlbcopiers
            • Oct 2007
            • 34
            Re: Sharp AR M455
            Maybe I'm not explaining it correctly.
            You cannot place an original on the glass and push the print button and a copy comes out.
            After hitting the print button, the screen asks if this is the last page to be scanned. You have to acknowledge this before the machine will give you a copy.
            I think because it stores the image or images before printing multiple copies. But they only want one copy and want to hit the copy button and be done.
            Thanks.
            • NeoMatrix
              Senior Tech.
              • 3513
              Re: Sharp AR M455
              It sounds like the machine is in scan mode by default, instead of copy mode default.
              • bilyahn
                • Dec 2006
                • 1470
                Re: Sharp AR M455
                Thanks.
                I understand "exactly" what you are describing. Maybe you should try my post settings. What's the worst that can happen!
                Bil
                • tmaged
                  Owner/Service Manager
                  • 1891
                  Re: Sharp AR M455
                  Bil
                  Bil is correct. There is SOME default function that has been changed that requires the machine to know when the last page is scanned. Whether it's duplex, stapling, grouping etc. This doesn't just happen on it's own, someone has changed it.
                  Hope that helps !
                  -Tony
                  www.dtios.com
                  Become a fan on Facebook
                  • mlbcopiers
                    • Oct 2007
                    • 34
                    Re: Sharp AR M455
                    Bil
                    Thank Bill, you were right on.
                    • bilyahn
                      • Dec 2006
                      • 1470
                      Re: Sharp AR M455
                      You're welcome
