Sharp mx-m550 image cut off
  • davebtech
    • Apr 2015
    • 176
    [CQ] Sharp mx-m550 image cut off
    Top of portrait copy about 1 1/2 inch cut when using document scanner does not do it all the time.network prints never a problem.feeder has new tires. Tried sim 50 nothing. Someone has mentioned a CIS pwb in prior posts ? Help appreciated thanks Dave
    • 23007
    Re: Sharp mx-m550 image cut off
    Does it affect scans? If no, I'd consider the laser. Especially if you had a few random laser related codes stored.
    EDIT: Oops! I missed that part about prints being OK. =^..^=
    • bigrobmass
      • Aug 2015
      • 7
      having same problem, tried different scan board and whole feeder unit, if you figured out please post fix thanks!
