Motor start rotating and does not stop (SF-1116)
  • ali_3000
    hi
    I have Sharp SF-1116 when i power it on the motor starts rotating and it does not stop.
    Please help me
    • 23007
    I think if you wait ~5 minutes you will see the toner add condition. =^..^=
    • ali_3000
      i wait more than 10 min and i don't think that warm-up takes this time
      • montana
        • Aug 2008
        • 392
        point of view
        hi.theres many reasons for this malfunction .first you have to check the level of the toner.then you check the sensor which exists on the back of the developer tank .check the tank inside the mechanism and you can try another tank to make sure theres no problem with controller board.check the simulation mode 25 to make sure of the sensor reading.
        and i wish you goood luck my dear
        • ali_3000
          Thanks man
          • bechir00011
            • 24
            i have Sharp SF-1116 .the technicin messge flashes don't stop and the machine don't reply anything .i can't enter the simulation code because the machine is blocked.i turn off/on , when i open, the same thing .
            can you help me please.
