MX-M550N Jam Code MPRD2_N2
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [Jamming] MX-M550N Jam Code MPRD2_N2
    We have a MX-M550N that jams out of Tray2 (right side) of the Top Large Cassette only. ALL OTHER TRAYS work fine, including Tray1. I have replaced the entire Tray1/Tray2 Cassette, the Developer Unit and Drum Unit because of Developer dumping down into the trays (made to tray 3 in fact). This machine was NOT jamming before the dumping occurred. When I pull out the Tray1/Tray2 Cassette and that overpass guide drops down I see 1 Sensor there and no way to get to it. I believe that Developer has gotten into it, but its covered top and bottom by solid steel plates! Do I have to disassemble the entire machine just to get to it?
    Is that sensor even the problem? Are there other causes for constant MPRD2_N2 jam codes?
    Help!?
    Thanks in advance.
    It does not matter how slowly you go as long as you do not stop. –Confucius
    • 22999
    Re: MX-M550N Jam Code MPRD2_N2
    I think I'd replace the pickup clutches and vertical path clutches. I've seen this on a number of different models. Developer starts to dump and is magnetically drawn right into the electromagnetic clutches. First tray #1 fails, then tray #2, then tray #3 ...
    • faxman28
      • 436
      Help!?
      Thanks in advance.
      tandem tray transport unit can be removed by remove front cover to expose the screws on frame by tray 1 and then there are screws on left side where paper comes up from tray 1 ,then move transport unit to the left to release and there's a cn that needs to be disconnected to remove unit completely. transport rollers are probably contaminated by developer . sensors are also on unit. check service manual for exact procedure. it's been awhile since I have removed this unit.
