AR-M455 Eating Developer Units
  • Buddy
    • Aug 2009
    • 285
    Hi All,
    I have an AR-M455 that is destroying developer units. I have put two new units in this machine and both DV units lasted a couple of weeks! Eventually the mag roller locks up. I noticed on the front side there is a piece of mylar that gets mashed. It looks to me like there is a lot of pressure being put on the mag roller, on the front side. I looked at the mechanism that lifts the dev unit and it looks OK.
    What am I missing?
  • benalvarez
    • Feb 2015
    • 27
    Re: AR-M455 Eating Developer Units
    All this and no grinding noise?
    • benalvarez
      • Feb 2015
      • 27
      Are your development units brand new? Have you pulled the rear panel and determined that the main gear assy. is working well? Is the developer still in the units? Or is it getting pulled out by the drum?
      • Buddy
        • Aug 2009
        • 285
        Brand new units.
        • Buddy
          • Aug 2009
          • 285
          As I mentioned, they are locking up to the point that the mag roller is very difficult to turn. Still have all the dev in them.
          • ZOOTECH
            Senior member of CRS
            • 3375
            Is the left hand slide-out door latching properly, specifically the rear latch?
            • Buddy
              • Aug 2009
              • 285
              Yup, door latches fine.
              • QCCDUDE
                • Apr 2015
                • 9
                Can you post a photo of the dev units
                • Buddy
                  • Aug 2009
                  • 285
                  Don't have a pic Dude. The unit is still in the machine. Threw the others out. I can tell you there is a wear mark around the mag roller near the front side. (as you're looking at the machine) The drum is worn in the same place, so the drum is putting pressure on the mag roller, but I don't see anything wrong with the drum unit.
                  • benalvarez
                    • Feb 2015
                    • 27
                    Is it possible that the drum housing could be warped or cupped from the fuser's heat? Remove the drum housing and lay it on a flat surface, like a desk and see if it rocks? Just a thought...
                    • QCCDUDE
                      • Apr 2015
                      • 9
                      Also try different drum housing unit...
                        • 23009
                        Clearly something is making contact with the mag roller. It should be fairly easy to determine since the only things you need to concern yourself with are within a couple of millimeters of the mag roller. And you can probably discount the inside of the developing unit. I think I would remove the drum unit, and re-insert the developing unit and latch it in. Then remove the back cover and run the developing drive manually by spinning the gear by hand. If I remember correctly there is a clutch in the drive chain that you'll have to remove. If anything is touching the mag roller you should be able to identify where it's scraping. It will be on the registration assembly or on the drum assembly. Those are the only assemblies close enough to make physical contact. Pictures please. =^..^=
                        • nmfaxman
                          • 1702
                          What was the original call for when this started?
                          Sometimes you have to take a step back to move 2 steps forward.
                          • Buddy
                            • Aug 2009
                            • 285
                            The original code was an L4? Whatever it was, once I replaced the dev unit, the machine ran for three weeks without a code.
                            • QCCDUDE
                              • Apr 2015
                              • 9
                              L4-02 drum motor lock, sounds like somethings binding your motor drive what does the drum housing look like any scraping or abnormal wear on it.
