AR-M455 Eating Developer Units
  • Buddy
    • Aug 2009
    • 285
    #16
    Re: AR-M455 Eating Developer Units
    Nope, no wear on the drum unit housing.
    Sorry guys, the customer has decided to s*&t can the copier. (It has 720,000 copies on it.) So, this issue will have to remain a mystery.
    As always, thanks for all your input and ideas on this!
    • nmfaxman
      • 1702
      #17
      Kudos for not giving up. Means a lot in this business.
      • Buddy
        • Aug 2009
        • 285
        #18
        Well, apparently Sharp is putting out defective developer units. Just went out to a different machine that I replaced the developer unit in. SAME PROBLEM. Put a brand new DV unit in about two weeks ago and this one has the same wear marks on the mag roller.
        I might also note; These three DV units felt a little gritty when I turned them without developer in them, not the usual smoothness.
          • 22952
          #19
          Perhaps the doctor blade is set too tightly? Have you checked the doctor blade height? It should be 0.45mm (plenty of clearance). =^..^=
          • Buddy
            • Aug 2009
            • 285
            #20
            Good thought Blackcat. No, I didn't check them. Never had to from the factory. Definitely worth a look. Thanks
            • DINGO
              • 661
              #21
              • Buddy
                • Aug 2009
                • 285
                #22
                New developer.
                • joegerstner
                  #23
                  check the doctor blade gap I've had several where one side was off. The gap is .45 and the adjustment is in service manual
                  • Buddy
                    • Aug 2009
                    • 285
                    #24
                    Yup, the doctor gap was off on the one side. Adjusted it and haven't heard back, but I still think there was something wrong with a batch of units. They just felt gritty when I turned the mag roller BEFORE I put dev in. I received a warranty replacement from Sharp and it felt nice and smooth like they always have in the past.
                    Thanks to Dingo and Blackcat, and everyone else! As always, this site is a life saver.
