AR M455 Creasing paper
  • mlbcopiers
    • Oct 2007
    • 34
    I have a Sharp AR M455 with a lot of copies on it. It has just started to crease the paper. It appears to be happening in or before the fusing unit. I have replaced the upper and lower fuser rollers and have replaced the paper feed rollers. I am still getting intermittent creases in the paper.
    What am I missing?
    Thanks for the help.
  • harleyrider
    • Oct 2011
    • 348
    Re: AR M455 Creasing paper
    PS roller unit maybe or exit unit or shit paper. Seen all 3 cause it.
      • 23006
      Ditto that. Check for seizing registration roller bushings, and check to see if the paper dust collector is packed full. =^..^=
      • lcastillo5
        • Jun 2008
        • 32
        Did you replace the 4 fuser bearings when you replaced the fuser rollers?
