Sharp MX-4501N
  • tcypy1961
    • 773
    Sharp MX-4501N
    Is this Sharp MX-4501N known to always go into "adjusting print quality" or is there something wrong with the copier? Thank you for any help given.
  • drowranger
    • Jul 2015
    • 122
    Re: Sharp MX-4501N
    Check if the fuser heater lamps are working correctly on sim 5-2. can be fuser related.
    • ntbann
      • Jan 2012
      • 631
      Re: Sharp MX-4501N
      Also do a full calibration. Clearing all the half tones and also make sure to run 44-2 and 44-13.
      • spanky
        • Sep 2012
        • 468
        Re: Sharp MX-4501N
        See attached bulletin
        • walterman
          • 196
          Re: Sharp MX-4501N
          Spanky. beat me to it. Those box's have done that since day one believe me, every customer has complained about it. I tried making the above changes for a couple of customers, then I ran into color consistency issues, so I set them back to the factory settings. Also, The MX-4501 color is also compromised by cheap paper make sure your customer uses quality paper when making clicks.
          • tmaged
            Owner/Service Manager
            • 1897
            Re: Sharp MX-4501N
            More than likely the DV is oxidized & needs to be replaced. Even though the CQ may not look bad, process control isn't seeing what it needs.
            Subsequently it calibrates frequently.
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
