tosh 556-656 z folds
  • cpjim
    • May 2015
    • 47
    after addressing the firmware and 0/5 4532-4534 adjustments, we still get intermittent z fold jams usually on duplex only. the folded part of the copy has no image so it is happening before the drum. we have been chasing this problem around for quite a while. can anyone shed any light on this problem? thanks........
  • didi2005
    • May 2011
    • 401
    Re: tosh 556-656 z folds
    Normally Z-fold is due to registration timing, where normally after change registration clutch problem will solve, but not sure about this model because the last giant machine I've handle is e600...
      • 22936
      Take a look at the white idler pulleys on the right doors. The grease will get thick, and those rollers will get difficult to turn. Take the door apart and clean the bushings and shafts, and apply a couple drops of light oil to each bushing. =^..^=
      • cpjim
        • May 2015
        • 47
        thanks for the response, i'll check that stuff out. any more ideas?
        • Benjamino1
          Did you ever get to the bottom of this?
          I also have one doing it?
          Ben
          • cpjim
            • May 2015
            • 47
            we still see this problem on occasion. make sure the duplex unit is turning freely, clean all rollers and check all idler rollers, replace 3 transport clutches on feed units if needed. replace black actuator on left side door, the lower one. even after doing all this you we still see the problem intermittently.
              • 22936
              How many clicks? =^..^=
              • cpjim
                • May 2015
                • 47
                most of our 556-656's have between 1 million and 3 million, a few at almost 4 million.
                • arnh79
                  • 466
                  We're fighting with the same issue. When you say black actuator what are you referring to? Thanks.
                  Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
                  • cpjim
                    • May 2015
                    • 47
                    open the left side door , it's the lowest black actuator you see, on the door section. i think it's called the reverse section sensor. you get to it by removing the exit door cover. the soft black plastic actuator gets a flat spot on it and causes a timing problem.
                    • bryand
                      • 92
                      there is a tsb for this issue, an updated LGC board is available. Also be sure the machine doesn't have the defective a18 sensors in it.
                      • cpjim
                        • May 2015
                        • 47
                        thanks for the reply, can you elaborate about the defective a 18 sensor---jim
                        • bryand
                          • 92
                          there was a bad batch of sensors that Toshiba got from Sharp. If you look down from the top of the sensor you will see 3 tiny circles with a letter followed by 2 numbers. A18 is the defective lot. They are in 556 series,4540 series, finishers,6550 adfs, pretty much anything made between 2011 and 2013.. Its been a complete nightmare. A 4540c has almost 30 of these sensors and takes 8-10 hours to replace them all. They fail completely or work intermittently when dusty.
                          • cpjim
                            • May 2015
                            • 47
                            thanks for your help, i'll check that out----jim
