E-Studio 3520C
  • aAandy
    • Apr 2012
    • 370
    [CQ] E-Studio 3520C
    hello people
    i just did 3 colour PCU rebuilds (black PCU to be done later as one wrong drum was supplied) - new drum, blade, corona, grid, corona cleaner & developer using Katun bits,, did the calibrations as per the service manual
    machine vacuumed, blank lamps cleaned, ITB assy cleaned, laser slit glasses cleaned
    596604 prints on the machine - 54k full colour - 5 twin/mono colour - 542k B&W
    i'm having problems with lines in the direction of paper travel, most noticeable on light images specially blues, not noticeable at all on dark images
    in the sample provided you will notice lines in both directions, one set are from my dirty scanner - the ones i'm concerned about run from the sky to the ground and are in the direction of paper travel
    any pointers? do i need to remove the laser unit & clean it up?
    please help, i need to finalise this expensive job so i can bill the client
    many thanks in advance
    Andy
  • gliderider
    • May 2015
    • 131
    Re: E-Studio 3520C
    Hi:
    Doubtful that it is the laser from the sample. I would wait until I perform the K maintenance before being too concerned. Have you gone into Test Print mode?
    Power up in 04 and run the individual halftone tests with code 237 and see if you can isolate the problem to one specific color at least. You can also run codes 219 and 220. If the problem shows up across all colors then it's doubtful that the epu's are the issue. What shape is your 2nd transfer roller in?
    Best Regards
    Andrew
      • 23010
      Re: E-Studio 3520C
      I agree with gliderider. Black developing could account for the anomalies. We could tell more you printed some 15% fill CMYK samples like in the enclosed document, then scanned them back to this thread.
      It is possible, but unlikely that primary or secondary transfer would produce the voids in the feed direction.
      One thing that I did not read in your original post: Did you scrub the developer cylinders when the it was empty with a green scrubbie? Toshibas with the smooth developing cylinder tend to experience "developer slip" when the cylinder gets polished shiny. The symptom for that is voids crossfeed on one or more colors. The most convenient time to scuff them up is when the developing unit is empty, but it can be done full of developer also. Just scuff an area the full length of the cylinder, rotate 1/6th of a turn, and continue until you've made it all the way around. Do not concern yourself with the aluminum dust. It's not magnetic and will not affect development. Also did you stir the developers?
      Otherwise, I find no fault in your PM procedure. Once you get the black PMed and calibrated, if you still have an issue post back with your scans.
      • aAandy
        • Apr 2012
        • 370
        Re: E-Studio 3520C
        many thanks for the responses gents
        i considered the problem may be due to the black PCU not being done yet,, but thought i'd ask in case i missed something obvious
        transfer roller looks good
        i didn't see any need to scrub the mag rollers, they were in very good condition with no signs of polishing (though that may not be the case with the black)
        i will perform the test prints once the black is done & report back either way
        • aAandy
          • Apr 2012
          • 370
          Re: E-Studio 3520C
          completed the black imaging unit rebuild & calibration, then ran off 231's
          yellow is magical
          black is ok
          magenta isn't ok (dark lines instead but no void lines)
          cyan is terrible and produces those void lines in the previous piccy, looks like classic dirty corona
          i swapped the cyan & yellow drum units (corona assemblies included) and the problem stayed the with the cyan. Removed, cleaned and re-gapped the cyan Dr blade, checked mag roller surface good, checked developer coating of mag roller good, checked developer movement & mechanical operation good - problem remained identical
          i ran out of time, so couldn't fit in any stop tests, to see if the imaging unit latent image is good, or the transfer belt latent image either
          cant be the imaging units right? gotta be either primary transfer to the transfer belt, or dust/mirror haze in the lasers no?
          piccies to follow later
          • aAandy
            • Apr 2012
            • 370
            Re: E-Studio 3520C
            piccies - A4, lines in direction of travel - 600 by 600 res
            cyan.pdf
            magenta.pdf
              • 23010
              Re: E-Studio 3520C
              Have you wanded the laser slit glasses? It's usually enough to use the wand in the front door, but if the developer has seriously dumped, occasionally it is necessary to vacuum the area first, then wand the slit glasses. The cyan needs it most. =^..^=
              • aAandy
                • Apr 2012
                • 370
                Re: E-Studio 3520C
                more times than i can count lol and the problem remains 100% identical - no changes to the position or width of the void lines, no matter what i've done thus far
                i'll be returning tomorrow to check the latent images & let them guide me - bad latent image on drum & i'll dismantle/clean the laser - good latent image on drum & i'll attack the transfer belt assembly
                p.s. before i did any work on the machine, the magenta developer was depleted and producing the wavy effect you get with a lack of dev - i'd hate for the machine to dump dev into the waste toner again, what should i be looking for/checking?
                  • 23010
                  Re: E-Studio 3520C
                  The diagonal voids you saw in the magenta developer is the entirely normal result of failing developer. No other cause. In about 60K color copies you'll see it again, I'm sure. If your customer ignores the voids, eventually the patches will be so poorly developed that you'll get CA00 or CE40 codes. If you arrive with a CA00 on the screen, immediately pull the primary transfer belt and look at the patches. You'll be able to see which color(s) are developing poorly. =^..^=
                  • michaelc
                    Field Tech
                    • Mar 2011
                    • 590
                    Re: E-Studio 3520C
                    5665165212
                    It didn't say that I couldn't do it in the manual.
                    • aAandy
                      • Apr 2012
                      • 370
                      Re: E-Studio 3520C
                      update
                      the void lines were caused by a dirty laser unit, mirror & slit-glass haze - so that part is concluded
                      if you have a look at the magenta (same image as above), you'll see some dark lines & lighter stripes in the direction of travel, this is identical on magenta, cyan & black
                      the only thing i haven't gone to town on yet is the transfer belt assembly - is there anything else which could cause that exact pattern to be repeated on every colour?
                      any further pointers very much appreciated
                      • Turtle-92
                        • Nov 2015
                        • 6
                        Re: E-Studio 3520C
                        It looks to me like the laser ,i'd pull it out and clean both sides of the glass
                        • mazin999
                          • Feb 2016
                          • 9
                          Re: E-Studio 3520C
                          good machine and it's very usfull
