light copies estudio 455 and 456
  • Doctor
    • Sep 2010
    • 133
    Hello everybody, i changed drum developer and cleaning blade on estudio 455 and 456. Everything was fine initially, but after running large continuous copies, the copies becomes faint. I manually added toner to the developer and its fine for a while but comes back faint after some copy runs. Pls can someone help. Thanks
    • 22999
    Re: light copies estudio 455 and 456
    Did you reset your counters and do the developer stir after your PM? There is also a quality calibration. =^..^=
    • Doctor
      • Sep 2010
      • 133
      I did thru PM mode. Both developer initialisation and counter reset is done automatically. However I did not change other PM parts I only turned them off to remove the Time for Maintenance Message.
        • 22999
        Originally posted by Doctor
        I did thru PM mode. Both developer initialization and counter reset is done automatically. However I did not change other PM parts I only turned them off to remove the Time for Maintenance Message.
        Which other PM parts?
        • Doctor
          • Sep 2010
          • 133
          I did not replace main charger, transfer roller, fuser parts
            • 22999
            The sawtooth and grid could certainly account for your light copies. =^..^=
            • Doctor
              • Sep 2010
              • 133
              Changed charger still same had to add toner manually to the developer everytime.
                • 22999
                Well that isn't going to be very practical. Have you tried running the toner motor in 03 Mode? =^..^=
                • Doctor
                  • Sep 2010
                  • 133
                  Yes I did and the motor is OK. I wonder why the copiers are not sensing toner is low. This happened after changing drum developer thru PM mode.
                    • 22999
                    There is no reason that you shouldn't use 6S-01 to stir your developer. I do it frequently, without any problems. How many copies on the developing unit? Does it make that growling noise when the texture on the developing roller starts rubbing against the doctor blade? Or maybe the toner sensor has just failed? Are you certain that the developer is agitating? No loss of developer drive?
                    If it were me, I would visually examine the main drive. It's surprisingly easy to access. If the main drive looks okay, and I confirmed that the developer was agitating, then I would order a toner sensor and replace it. =^..^=
                    • riyadh hossainbd
                      • Dec 2015
                      • 239
                      First, toner sensor cleaner/toner sensor /cable that is connected to dv unit
                      Second is lgc board
                      • riyadh hossainbd
                        • Dec 2015
                        • 239
