e studio 556 per maint fuser web-- won't clear
  • cpjim
    • May 2015
    • 47
    we've got 2 of these now showing the fuser web maint message and we can't get it to clear. the copiers do not need a pm, all pm counters have been reset, the fuser has been swapped, the fuser connectors have been checked for paper scraps and been replaced. in the test mode, the web sensor appears to be on, has any one seen this problem before? ( also, the firmware has been re-loaded, no help) tia--jim
    • 23009
    Re: e studio 556 per maint fuser web-- won't clear
    If you print off the 9S-103 maintenance list, what replacement interval is listed? What number of rotations before replacement? Sure, you may have reset the counter in 6S-02, but if the replacement interval is "0", then it always shows PM warning. There is a place in 08 mode to set that interval.
    Note: If you notice other maintenance counts gone wacky or a repetition of today, you might have a failing NVRAM. =^..^=
    • cpjim
      • May 2015
      • 47
      all the pm intervals are set at 500,000. thanks for the reply post.
