Toshiba 161
  • Orion2010
    • Jun 2015
    • 176
    Toshiba 161
    Hello to all,
    i have problem with toshiba 161 I change drum and blade, but after a little time when I make copier in the paper appears shadows like in the picture
    • 23009
    Re: Toshiba 161
    It could be primary charge, or developing, maybe both. Personally I would order a sawtooth, grid, and developer. =^..^=
    • didi2005
      • May 2011
      • 401
      Re: Toshiba 161
      Open cover/doc feeder, perform copy and see the outcome, if no solid black or many white patches, probably the developer material not enough~~~
      • riyadh hossainbd
        • Dec 2015
        • 239
        Re: Toshiba 161
        I think your drum is not good, try another one
        • Harry
          • 228
          Re: Toshiba 161
          This is a sharp and if you change Drum and Cleaning Blade change also Developer the Developer dont have a good duration about 60K Get also a lock at the Developer Case Somethimes it gets out of Positione and lost Developer.
          Good Luck
