ES 6520C error C471
  • aAandy
    • Apr 2012
    • 370
    [Error Code] ES 6520C error C471
    hey people
    machine first came up with C472 which i reset & it now displays C471
    checked fuser unit throughout, lamps, thermal breakers (thermostats), thermistors & connectors and all are fine, so i guess the IH board fuse is blown, or the board is stuffed
    silly question, is access to the IH board from the machine rear? what kind of fuse should i take with me? i have the service & parts manuals but couldn't locate concise information on location, no removal procedure and no piccy of the IH board
    any assistance greatly appreciated
    thanks in advance
    • 23009
    Re: ES 6520C error C471
    The IH board is at the top of the rear frame. You've got a couple of boards to remove to get there.
    But before you do that, check that the lower right side door interlock is made. I've seen the shoulder screws back out, and the switch actuator doesn't actuate. That can give you a C471. =^..^=
    • aAandy
      • Apr 2012
      • 370
      was just looking at the "AC Wire Harness" diagram and wondering if this machine may be susceptible to interlock switch problems,,, used to have interlock switch problems alot in the 80's n 90's
      thanks heaps for the suggestion!!! muchos grassyass
      oh, if it's not the interlock switch, do you happen to know the fuse type & rating?
      • Sriyanjan
        • Apr 2015
        • 79
        • Sriyanjan
          • Apr 2015
          • 79
          [emoji16] [emoji15]
          Sent from my HTC Desire 820s dual sim using Tapatalk
            • 23009
            Sorry, I don't know that. =^..^=
            • riyadh hossainbd
              • Dec 2015
              • 239
              change ih board
