e-studio 202L
  • Jaws
    • Oct 2007
    • 236
    e-studio 202L
    Copies are moving on test prints, but machine is not jamming. Sometimes the first copy out is dead on in the middle, but after that all copies are six inches off. See attachment pic. Thanks in Advance.
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: e-studio 202L
    The rubber pads on the paper/tray feed solenoids may have deteriorated. You may need to replace the rubber pads. The rubber on the solenoid actuator becomes sticky with age and holds the paper feed solenoid open.
    Make sure you clean the old pad off completely, and maker sure replace it with a similar pad with the same thickness.
    HTH
    • Jaws
      • Oct 2007
      • 236
      Re: e-studio 202L
      This model uses magnetic clutches and if they were slipping the machine would record a jam. Thanks for your post, I welcome all answers.
      • NeoMatrix
        Senior Tech.
        • 3513
        Re: e-studio 202L
        I thought 202 where similar to the ES205...
        How old is the machine ? Is it in a dirty dusty environment ?
        Try cleaning the mag-clutchs and shafts. If the clutchs are binding the same thing will happen.
          • 23009
          Re: e-studio 202L
          This is a dinosaur. It was released in 2006. They were fairly well built, and we have dozens of them still under contract. It uses magnetic clutches that do not disassemble. It's fairly common for the set screw to back out of the registration clutch so it spins free, and that might account for your registration issues.
          Toshiba E STUDIO 202L Toner Cartridges
          • Jaws
            • Oct 2007
            • 236
            Re: e-studio 202L
            I checked the two set screws on the registration clutch and they were good and tight. I put it back together and it started working, but not for long. Went out today and cleaned the registration photo sensor and the 1st transport photo sensor and now it seems to be working correctly. Thanks for everyone's input.
