E-455, multiple jams at vertical paper pass (EB-50, E-550)
  • Oystercopy
    • Oct 2009
    • 623
    I have replaced one of the sensors under the door cover, but it seems like the other one is bad as well. Part number C0-17839000 is the sensor for both in that section, one paper pass and one for opening/closing the door. I was fighting this machine for a while, but didn't realize that I could have had TWO sensors out at one time! I noticed that the part number for these sensors had changed in RIBON, so I wonder how many of you guys have had to replace these stupid things? The machine never jams from Tray 1, but from Tray 2 and the LCC, she'll jam.
    Thanks in advance!
    OC
    • 23009
    Re: E-455, multiple jams at vertical paper pass (EB-50, E-550)
    Other causes that I've seen for EB50's are:
    1) Pickup clutch slipping.
    2) Separation roller with flat spot
    3) Bad patch of paper stuck together
    4) Separation torque limiter in need of grease
    • Sriyanjan
      • Apr 2015
      • 79
      Wht about copy counter ?
      Sent from my HTC Desire 820s dual sim using Tapatalk
      • riyadh hossainbd
        • Dec 2015
        • 239
        just change two sensor located in a black plastic
        • cpjim
          • May 2015
          • 47
          also, replace the 2 actuators for those sensors.
          • Oystercopy
            • Oct 2009
            • 623
            I looked at the actuators, they look fine and not worn at all. Are you saying there is something about them that's defective as well?
            OC
            • Sriyanjan
              • Apr 2015
              • 79
              E550 mostly came from ADU sensors.
              • cpjim
                • May 2015
                • 47
                they get worn down to a point and affect timing, but sometimes get 061 codes with that problem.
                • riyadh hossainbd
                  • Dec 2015
                  • 239
                  For EB50 u must have to change two sensor together located black cover near aligning roller
                  • Sriyanjan
                    • Apr 2015
                    • 79
                    And check 2nd drawer transport cover for EB50. Press it using your hand while you feeding from 2nd drawer
                    • Sriyanjan
                      • Apr 2015
                      • 79
                      But its not came from 1st drawer. So i think [emoji18]
                      • Bicyclerepairman
                        • 63
                        Sensor actuators do get worn, guide and mylars that sensors are housed in get worn, guides on side door around bypass roller get worn, try extra wrap on actuator springs
                        • Oystercopy
                          • Oct 2009
                          • 623
                          The problem was never solved, although I suspected it to be a pinched wiring harness somewhere. Sometimes, while running paper, if I "shook" the machine, paper would continue feeding without a jam. I immediately went for the tray input sensors, which are known to go bad, but that wasn't it. I replaced the entire Feed Units, the entire Transport Door from another machine... same thing. I will just end up using this one for parts, unfortunately!
                          OC
