weird problem es-455
  • riyadh hossainbd
    • Dec 2015
    • 239
    Hi buddy recently I faced a weird problem that is background dirty back side of the paper when do single side copy. Any idea ??????
    • 23009
    Re: weird problem es-455
    Generic toner?
    How many copies on the developer?
    • riyadh hossainbd
      • Dec 2015
      • 239
      Generic toner?
      yea its generic toner and developer about 10000 copys and background dirty about 3" or 5" middle side of the paper( back side of paper when do single copy)
        • 23009
        I'd do a developer change and install an OEM toner. If that clears it up I would advise against the Generic toner. If you're providing the generic toner you've got a problem explaining why you use it.
        If the customer is patient and wants to save some money, you can just change the toner cartridge, then let the generic toner diminish gradually. The quality will get better and better over a period of a couple thousand pages. =^..^=
        • riyadh hossainbd
          • Dec 2015
          • 239
          Thank you so much
          • arnh79
            • 468
            I've also seen this on machines where the 2nd transfer roller is due to be replaced. If you've got 300-400k on the machine and are using the original 2nd transfer then changing that might fix the problem.
            Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
