tosh 655-557 fuser web problems
  • cpjim
    • May 2015
    • 47
    all of the sudden we have a rash of these webs sticking to the ufr and some times even the lfr. we use only tosh oem fuser parts. after sticking to the fuser roller it usually breaks and wraps around. we went for ages with no real web problems, has anyone seen this? thanks--jim
    • 22999
    Re: tosh 655-557 fuser web problems
    Is the web advancing properly? If not, the upper roller will wear right through the web, and the upper roller will get a heavy buildup of toner. And you'll get duplex jams.
    This is what I discovered:
    At the last fuser rebuild, a pin backed out of the connector. =^..^=
