error code cdfo reoccurring in es 455
  • riyadh hossainbd
    • Dec 2015
    • 239
    hi recently copier showed "CDF0" code then I changed MOT2 board then copier ok, but after a week later it show again "CDF0" code. Now what should I do ?? Have any mechanical setting to avoid this code ????
  • gliderider
    • May 2015
    • 131
    Re: error code cdfo reoccurring in es 455
    Hi:
    The code you posted can be caused by a sticking or out of position jogger. If you remove the turn guide ass'y it will expose the jogger. If it does not slide back and forth smoothly or the then clean the shaft. Also check the bushings and make sure the gear is still on on the end of the shaft. When the turn guide is replaced the jogger motor arm must align with the jogger so it will move correctly and initialize or ot will throw the cdfo error you're erperiencing.
      • 23008
      I saw CDF0 a couple weeks ago. It's the code for the offset shift mechanism.
      The last time I saw this all the screws for the exit assembly were stripped out. The exit assembly was wobbling around enough to have the shift motor disengage from the shaft. I re-drilled and tapped the front frame to 4mm, and there was a threaded block at the rear, again re-drilled and tapped to 4mm.
      The threaded block was a bit more difficult to tap. =^..^=
      • riyadh hossainbd
        • Dec 2015
        • 239
        just disconnect offset tray motor and disconnect offset tray sensor copier is ok
          • 23008
          Maybe this document will help. It seems that that particular series of machine is coming of age. =^..^=
