E257 F106 error, now it keeps rebooting
  • DRKNITE
    • Aug 2025
    [Error Code] E257 F106 error, now it keeps rebooting
    Customer called with an F106 error. When I got there I could not get into any service modes, 3C, 4C, 08, even tried updating firmware, 49.
    About a minute or so into the Toshiba ribbon screen it just shuts down and reboots.....
    There was a power outage a couple days prior but the customer has been using it for a day since.
    I don't see any bad capacitors or fuses.... at a loss here....
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: E257 F106 error, now it keeps rebooting
    Usually the f100's are hdd related but based on what you are describing it could be a bad board, memory module or nvram issue..
    I do not have the book in front of me to look the code up.
    • didi2005
      • May 2011
      • 401
      I did encountered similar issue where MFP keep rebooting, not able to enter 08 or 49 mode...due to HDD faulty...
      • tech07
        • Aug 2008
        • 410
        Your only solution is a new HDD
          • 23009
          Wipe Drive + Firmware. You'll want to follow the procedure in the service manual. =^..^=
