ES450 with C010 code. Main drive
  • Desert Rat
    • May 2008
    • 1089
    It started out as routine work. It was mis-feeding from by pass and tray two. All the feed rollers were over their
    rated life. So I changed them, re-assembled the machine and test. It ran fine from tray 1, but tray 2 & by pass tray
    give the C010 code when it feeds the second sheet.
    I cleaned the sensors and rollers when I installed the rollers. Took both of the feed assemblies out and checked for
    binds, none. Checked it with the sep roller in and out of play. The sep rollers turn in the right direction. Swapped the
    feed units, same symptoms. Took the DV unit out and ran the main drive output program. No funny noises. Starts
    and stops smoothly. Must have done something funny when I put the by pass in.
    I have the books and followed the directions.
    Has this happened to anyone else? What did I miss???
    DR
  • didi2005
    • May 2011
    • 401
    Re: ES450 with C010 code. Main drive
    What is your meter clocked? I do encountered problem with main drive~~~
    • Desert Rat
      • May 2008
      • 1089
      I have been servicing this unit for 8 years. I know it's old but it has always
      run pretty good. The customer only does about 2000 per month when they're
      busy. And they have not been very busy for a while.
      The meter is at 494K.
      DR
        • 23008
        Usually what you find is the rear developer bushings leaking. The developer acts as an abrasive, combined with the additional drag from the developing unit causes the MFP to eat three gears in the main drive pack. The confirmation will be the pile of developer in the back of the cavity.
        Is it possible that another tech replaced the developing unit, but did not look at the mostly worn gears in the main drive pack? =^,,^=
        • Harry
          • 228
          change or resolder main motor i have had this problem many years ago resoldering do the trick!
          good luck
          harry
          • Desert Rat
            • May 2008
            • 1089
            I dug into this machine earlier this week and found that the gear pack for the main drive motor was gummed up with half dried grease. I just took the gears off one or two at a time, cleaned and re-lubed. Put it back together and it works fine. Thank you everyone for you assistance. How could I fail with this kind of support? Thanks again DR
