Scan to email stopped working
  • Valintine
    • Jan 2012
    • 147
    Hello
    Yesterday 6/14/16 I started getting a number of calls with customers saying the scan to email that I had set up stopped working. It turns out all of the customers that called are using gmail and have machines in the es4520c family. Has anyone else seen this?
    Thank you in advance for any help.
  • Valintine
    • Jan 2012
    • 147
    Re: Scan to email stopped working
    I forgot to include that machines in the es4540c family are working with the same settings. Here in the shop I have put two copiers on the network using the same gmail account and settings. The 4540c is scanning with no issue and the es2330c is failing. The message in the log is Failed smtp authentication
    • NSD
      • Aug 2011
      • 44
      I am seeing the same issue. EbridgeX and EBridgeNext are fine but Ebridge3 will not scan via GMail (or other similar providers). It is not a firmware issue as far as I can tell but I have not see and EBridge3 working with a gmail account for a couple of weeks but newer machines are fine.
        • 22997
        According to our IT it is a firmware issue. Patches have been issued on the 282/283 version 999; 2500C/3500C/3510C version K2; 4520C series, 455 series, 6530C series, and 855 series version 364. It's specific to Gmail. Our IT has been barraged over the last few days. =^..^=
        • NSD
          • Aug 2011
          • 44
          Toshiba Europe do not have that firmware version available. Do you have a copy I could download for the 4520 series to test.
          • dak327
            • Jun 2016
            • 4
            having same issues with 3530c/ 4520c series. At first I was just retyping in password under smtp settings, that worked fro a couple O'days.
            Now back to ground Zero, Help!!!
            Please
            • arnh79
              • 467
              blackcat already answered it, gmail changed a security setting (I'm assuming) and Toshiba has posted a f/w fix. I'll be testing that tomorrow since it just started happening to my customers this week. Gonna check for f/w and see what happens.
              Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
              • dak327
                • Jun 2016
                • 4
                Thanks for update!!
                • NSD
                  • Aug 2011
                  • 44
                  I have had an odd development today. We have upgraded a machine because of the issue and i was going to apply the us firmware but before i did i put it on our network and tested it and it worked fine. I tried a another customer and theirs still fails. I now have 2 machines both 2330s. Both on firmware 331. Both in our workshop. 1 works. 1 does not.
                  Sent from my SM-G920F using Tapatalk
                    • 22997
                    Which of these machines are scanning to Gmail? Gmail only is affected. =^..^=
                    • NSD
                      • Aug 2011
                      • 44
                      Have tried several free services all with the same result. Authentication failed.
                      • arnh79
                        • 467
                        We haven't received those f/w versions here in Canada. The latest version available from Toshiba Canada is quite old now, v331 from Nov 2014!
                        Hopefully see a release soon here.
                        • Fattdaddy
                          • Aug 2012
                          • 38
                          Hi Blackcat
                          Our distributor doesn't know of the firmware change. Was it recent? Looking for the firmware for a 3510c.
                          Thanks for your help.
                          Don
                            • 22997
                            Originally posted by Fattdaddy
                            Hi Blackcat
                            Don
                            All others are dated 14 June 2106
                            The 2500C, 3500C, 3510C is dated 24 June 2016. The original firmware file link was corrupt. =^..^=
                            • yansyats
                              • Jun 2016
                              • 8
                              Originally posted by Valintine
                              Hello
                              Hi Valentine,
                              For security reasons, gmail accounts was secured by GMAIL. You must login your gmail account in gmail and simply go to "My Account" > "Connected apps & sites" under "Sign-in and security" > you must enable the "LESS SECURE APPS".
                              Try the scanning after.
