Toshiba 5540c colored line across page after start up
  • NextGenCody
    • Aug 2025
    Hello,
    IM working on a Toshiba e-studio 5540c and this machine seems to be very temperamental.One of the problems i have encountered with it has been a line or mixed colors across the center of the page after it starts up. The line only lasts about 4 copies then goes away. I have registered and calibrated the machine changed the transfer belt cleaning blade. the problem still persists. I have not found anything in the manual about this problem. Thank you.
    • 23010
    Re: Toshiba 5540c colored line across page after start up
    Do you have any samples for me to look at? =^..^=
    • Cfabrega
      • May 2016
      • 5
      5540c
      Originally posted by NextGenCody
      Hello,
      i have the same problem. any solutions?
        • 23010
        Same question. Where's the sample? =^..^=
        • bruce 49dcs
          • Jan 2017
          • 140
          it sounds like remains of the auto calibration pattern after start up in your book you will find the 08 code to shut off auto calibration try that and see if it goes away
            • 23010
            ... or you could figure out why the primary transfer belt is not cleaning off the color registration patches properly. Shutting off auto calibration won't solve a belt cleaning issue. =^..^=
            • bruce 49dcs
              • Jan 2017
              • 140
              shutting off auto cal was not meant to be a fix but to troubleshoot the problem by process of elimination after the problem is solved auto cal should be turned back on
