4520c can not get Top Access
  • Fattdaddy
    • Aug 2012
    • 38
    Placed 2 4520c rentals. I can ping and print but can't get to top access to set up email. Could this be a network issue or could the machine block access?
    • 23009
    Re: 4520c can not get Top Access
    Two possibilities:
    First, what browser are you using. I seem to have the best results with Firefox, but try others.
    Second, skip the customers network and connect directly with a crossover cable. Some networks block all but a very specific group of web addresses. I had to do this at a bank. DHCP would not assign an address to my laptop, and when I set a static address, it blocked all but the companies website.
    • didi2005
      • May 2011
      • 401
      It might be blocked by customer network such as proxy, or the default 80/8080 port is blocked~~~
      As what BlackCat suggested, try bypass customer network~~~
      • Fattdaddy
        • Aug 2012
        • 38
        Tried with laptop, same issue can ping and print but no top access.Tried setting up a network with laptop,4520 and a separate router and still same issue. Tried google and firefox. Anything to suggest?
