TOSHIBA ST355
  • jvargas
    • May 2009
    • 44
    TOSHIBA ST355
    Hello. I have a problem when i turned on the machine the green ligth of line of fax is turned on and never turn off and if you press the key SCAN a red ligth in front of the machine such as a jam turn on. I can SCAN and PRINT but i need how to reset this ligths.the machine has the last version SYS330. THANKS.
    • 23009
    Re: TOSHIBA ST355
    Can we assume that this is an e Studio 355 MFP? I had to stand on my head to view your photo.
    First, I would check the phone line with an analog handset to see if the phone line is working properly. If it is, then I would do a 1*-100 and 1*-102 fax initialize. =^..^=
    • jvargas
      • May 2009
      • 44
      Re: TOSHIBA ST355
      i disconect the fax system and still the light
        • 23009
        Re: TOSHIBA ST355
        Disconnect how? Disconnect where? And the initialize: did you do that? =^..^=
        • jvargas
          • May 2009
          • 44
          Re: TOSHIBA ST355
          i release the ribbon from the SYS PCB.
