E Studio 450 Paper feed Units
  • yormets
    • May 2009
    • 336
    I have an old E450 that needs its paper feed units rebuilt. I brought out some units from a 451C however they didn't quite fit. I have access to E353, E350, E452 units as well as 2830 and 3510 units. Are any of these going to fit the 450 so I don't have to rebuild the units at the customers place?
    Roy
    • 23009
    Re: E Studio 450 Paper feed Units
    The E353, E350, E452 paper feed units should all work for you. Don't forget the registration and paper feed clutch, both on the rear frame. =^..^=
    • yormets
      • May 2009
      • 336
      But first I will show them my heroic efforts to solve their issues. All new feed tires and such. I can hear some clutch rattling on warm up. Perhaps if I wet it down with some WD everything will be fine! I would suspect the feed. Are they still available? They have had this thing since I sold it to them in 2008. It's still below 150,000
        • 23009
        I hope you don't mean WD40. That can cause serious damage to any plastic. You can work alcohol into the clutches until it start coming through clear. They cannot be disassembled though. As far as I know, clutches are still available: Toshiba E STUDIO 450 Clutches
