aftermarket hard drive for es 556 and 557
  • cpjim
    • May 2015
    • 47
    can any recommend an brand name hard drive that will work in a 556 or 557 ( not purchased from Toshiba) thanks in advance.
    • 23009
    Re: aftermarket hard drive for es 556 and 557
    Hytec Circuit Board, Print Controller, Stapler, Power Supply, Fuser Repair Catalog
    G0-00732000
    • bryand
      • Jul 2008
      • 92
      You need to use Toshiba drives with wipe technology. They are expensive and fail daily. Also before you update firmware on the newer machines you should check 05-9065, if the value of c5 is 1 or more you will need to replace the hard drive before updating the firmware. If you don't it might work for awhile but it will error out f101 within a day or 2.
